Thread: TMGenc DVD Author - No audio file.
  1. #1
    I haven't had this problem until just recently when I am creating a DVD from exisitng DVD file; when I go to set it up in the Clip Selection portion the audio selection states that there is no audio file....when there clearly is because I played the DVD and the sound was there. Well, I tried anyway to create a DVD just with the video portion filled in thinking that this must be a mistake but sure enough, when the DVD burned there was no sound.
    Like I said, I thought I knew how to use this software correctly so have no idea what has happened.
    I should mention the DVD file has been put through DVD shrink first, which created the Video TS/Audio TS folders I then used to try and burn from.
    I'm a MEGA Super Moderator Baldrick's Avatar
    Posts
    43,713
    try demultiplex the vob to video and audio with rejig and then import in tmpgenc dvd author. it usually helps.
    read http://www.videohelp.com/forum/userguides/198813.php#step1b
    I went ahead and burned a copy of the movie not using TMGenc DVD authoring, since it wouldn't see the audio but then I figured if I put the newly recorded DVD, which plays fine in my DVD player, in my drive I could then use TMGenc DVD Author to author it. However, when I open it (the video TS) folder it still says no audio detected on the clip info page.
    Why doesn't it see the audio files or am I loading this wrong?
    I open DVD author, use Add DVD file, and proceed. Usually works fine. Any light to shed here?
    Member Sartori's Avatar
    Nov 2002
    Posts
    331
    It did that to me when I had v1.59 , when I upgraded to v1.6 it went away , you could try reinstalling it (and the ac3 plugin) . Going through a demultplexing every time is a pain in the bottom I would think .
    I think DVDshrink may have been the problem.
    Any other freeware out there that does this?
    ....actually, what I mean to ask is there any OTHER software to replace what DVD shrink does?
  1. How to Author a DVD with Subtitle file
    By Mark97213 in forum Authoring (DVD)
    Last Post: 21st Mar 2011, 09:46
  2. audio encoding: tmgenc dvd author 3 vs. tmpgenc plus
    By cL0N31 in forum Newbie / General discussions
    Last Post: 6th Jan 2009, 23:25
  3. TmgEnc DVD Author Menu Problem
    By powerkoala in forum Video Conversion
    Last Post: 25th Sep 2007, 13:19
  4. Tmgenc DVD Author
    Last Post: 19th Sep 2007, 06:02
  5. srt file and DVD Author 3
    By pYShTr in forum Subtitle
    Last Post: 4th Jul 2007, 04:28
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
