When I capture my video from my Hi8 camera to my hard drive thru my Plextor CoverterX PX-AV100U the sound gets recorded without problems but when I burn the movie the sound is broken on some tvs. I have to add that my camera has a mono output (meaning one sound output) and I only get the problem when I split the output to stereo thru a Y cable spliter. If I use the one output without the splitter and plug it into the left or right input it works without a problem....anybody knows how to split the sound without getting this problem....?
Your splitter might be stereo to begin with - in which case only one channel will go through.
Something like THIS will NOT work
http://www.bestbuy.com/site/olspage.jsp?j=1&CategoryID=cat08062&id=1069301596185&skuId...ref=25&loc=SMX -
Capture it with one channel. Demux the audio (virtualdub, save as wav), then load it into an audio editor. If it loads as 2 channel with one empty, copy the full over the empty. If it loads as a mono track, find the option to create a 2 channel mono track. Save the results, then remux (virtualdub again).
Read my blog here.
Your capturing device's audio input may have too low impedance for the camera's audio output to drive. You may wish to try 1) to get audio output from the headphone output or 2) to insert a small resister of 10 KOhms or so in seriese into the connection like below. In either case, you may need to adjust the audio level.
Camcorder Out >---/\/\/\/\--> Y-splitter
hiro -
This's what I've tried so far....
-recorded audio thru mic input(mono)...didn't work....
- recorded using left input which works but it plays when burned on one channel only, and used Sonic Foundry ACID 4.0 to create a 2 channel audio file....didn't work
Anything else I should try?
Mono / Stereo sound
By Anonymous16 in forum AudioReplies: 3Last Post: 13th Nov 2011, 20:09 -
Where Can I Buy a mono-stereo 3.5 mm mono to stereo L-adapter?
By solarblast in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 26th Nov 2009, 06:45 -
VHS Mono to Stereo
By Yaemish in forum AudioReplies: 2Last Post: 22nd Dec 2008, 11:42 -
mono to stereo?
By wingfan in forum AudioReplies: 5Last Post: 22nd Nov 2008, 13:44 -
mono and stereo?
By sharmine in forum Newbie / General discussionsReplies: 9Last Post: 12th Apr 2008, 22:24
