I recently purchased a Pioneer DVR-520H recorder. The only problem I am having is with the naming of the program that it records. I am not referring to manually entering a program name, but rather the name the unit assigns to the program when doing timed recordings. When I use VCR+ to schedule a recording, the unit will always assign a program name to that program after the recording is complete. And, almost always it is the name of the program that follows, not the one it just recorded. I have contacted Pioneer tech support and they did not have an answer. I have Adelphia cable, and it is connected directly to the 520-H. Any help would be greatly appreciated.
I've got a 420, same recorder minus firewire. What the recorder does is it titles the recording according to the last program it recorded. So obviously it's titling your recordings because of what's running after the show you recorded. The fix? Make sure your recorder's time is set EXACTLY right, down to the second. I set mine by my local TV guide channel as it's dead on as far as accurate timing is concerned. With EXACTLY the right time it should stop recording before it rolls over to the next program, and it should title it correctly.
Hi Steve,
Thanks for the quick reply. I had my 520 recorder time set to auto and to a PBS channel, but after reading your response I set the time manually according to my TV guide channel as you suggested. So far it has recorded the correct titles. Thank you so much for your help.
Vern
Pioneer DVR-520H: seeking advice for DVR-107-XA drive replacement.
By donglejack in forum DVD & Blu-ray RecordersReplies: 71Last Post: 12th Feb 2012, 08:24 -
PIONEER DVR-520H-S
By K_cin_az in forum DVD & Blu-ray RecordersReplies: 3Last Post: 12th Jun 2011, 02:18 -
Pioneer DVR 520H Timer Recording problem....
By Gypsy898 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 8th Mar 2010, 09:42 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 19:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 17:26
