I looking for a listing/recording interface somthing like Titan TV, anyone know where I might find it? Does the Guide Plus work with WinDVR?
I need one for Canada.
Thanks.
NO because the manufactuers of your hardware and software don't have an agreement with Gemstar's Guide Plus like ATI and Nvidia does. Information has to be embedded for the software to translate the data. You might want to check out Beyond TV of Sage TV. I use the former and have so for the past 3 years, and never have had an issue.
Zap2it is free. Works in Canada, with most TV viewing/capture apps.
Cheers, Jim
My DVDLab Guides -
I thought windvr works with titantv. Is it that titantv does not work in canada? I am not sure how ou would change the program used with windvr since it seems to automatically try titan? You might look at their website to see if they have any other programs listed. Have you gotten windvr to work stabilly? It does a good job when it works.
It appears there is a way to get titan to work in canada:
http://partners.titantv.com/ttv/help/HelpBar.aspx
About windvr and easygrabber 2.0 capture.
By MidnightMike in forum Video Streaming DownloadingReplies: 3Last Post: 15th Dec 2010, 18:32 -
Another troubled titan: Intel buys McAfee...why?
By ahhaa in forum ComputerReplies: 1Last Post: 21st Aug 2010, 20:05 -
windvr 3 and no sound
By goodtilltomorrow in forum Capturing and VCRReplies: 6Last Post: 12th Oct 2008, 17:34 -
WinDVR Input disappears while recording
By jacx3 in forum Capturing and VCRReplies: 2Last Post: 24th Feb 2008, 12:39 -
Titan TV PPV Movie Listings W/Dishnet USA?
By rhd in forum Capturing and VCRReplies: 0Last Post: 16th Dec 2007, 17:21
