I usually just burn to CD-R, but this time I have some longer videos that just won't fit on those disks. Anyway, I bought a few 4.7GB DVD+Rs, that from the box, atleast appear to be right for the job. My problem is, whenever I put one of the disks into my re-writer, my computer always tries to read it automatically, and won't stop trying until I take the disk out. It happens when I put them in my CD-Rom drive too.
Because of the above problem, I can never burn to those disks. Am I using the wrong type of disks or something? My current re-writer is a hp cd writer if that's any help, and it's a little old, and the disks are "Mirror" brand. I have some more re-writers around here if that's the problem, but I thought I'd ask before attempting to dig them out of wherever they are.
On the front of the dvd+r box, it says that the disks are suitable for video, data, games and music, so I assume that it is possible to use them with my pc? Suffice to say I don't know very much about these things.
You need DVD writer, not CD writer. Different laser.
BTW, how big are the files? -
Ah, hopefully I have one around here. I'll have to check. Thanks.
As for the files, the longest one is two hours and the others are a little under that. -
let me get this straight, you're trying to burn dvd+r's with a cd burner?
member since 1843 -
thats exactly what he was trying to do.. its a classic newb mistake.. so everyone settle down..
you're going to need to buy a dvd burner.. unless you already have one, which is unlikely.. people usually dont leave them laying around until they need to use it. -
Originally Posted by Harvey_DentonI usually just burn to CD-R, but this time I have some longer videos that just won't fit on those disks.
Problems Burning Movie Files onto blank Dvds-RW disks
By tealmarlin in forum Newbie / General discussionsReplies: 35Last Post: 1st Jan 2009, 11:18 -
Is there any burning software that will automatically span disks?
By Des in forum ComputerReplies: 15Last Post: 20th May 2008, 16:49 -
Will SATA Burners solve problem while burning 2 disks simultaneously?
By nick13 in forum DVD & Blu-ray WritersReplies: 3Last Post: 17th Jan 2008, 04:26 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 10:24 -
Problem burning DVD+DL disks
By ejai in forum MediaReplies: 16Last Post: 27th Jun 2007, 09:46
