Has anyone tried saving video from Final Cut Express using MP4 / h.264?
Wondering if it works.
Also does ffmpegx use h.264 for it's MP4? - the date on that program is from around Jan 05.
Results 31 to 38 of 38
I have read that in the past, and I suppose I should have said "can ffmpegx use h.264?" instead of "does it use..."
The manual says xvid in a mp4 container.
So the Final Cut Express question is still out there as well as can ffmpegx
use a h.264 codec for PSP.
I'll have to try it. -
An update on iPSP. I bit the bullet and purchased a licence for v 2.5.3. I can get some encodes to work, but having problems with VIDEO_TS to AVC transcode producing very large files. Support on http://support.kaisakura.com seems patchy. Anyone on this forum got experience?
AVC has yielded only large files for me. The encode times are also incredibly long (compared to the MP4 encoder)Originally Posted by pglock
iPSP's MP4 encoder (via Forty-Two) is the easiest method to use so far. Being able to choose the final file size is important when you have limited space!
My other issue is trying to take a DVD with several episodes and getting each episode compressed. I am only able to get the first one! -
In Forty_two you can choose which titles to convert from the dvd with the drop down "title" box. This allows conversion of all episodes on the dvd.
Sometimes the light at the end of the tunnel is a train. -
hows PSPware?
Whats the most simple software out there that will work on MAC to PSP on movie xfer??
PSP Test Clip: Need someone with a PSP to test for me!
By FulciLives in forum Portable VideoReplies: 5Last Post: 17th Feb 2009, 20:42 -
My XviD4PSP PSP video conversions are not supported on PSP
By godfist314 in forum Portable VideoReplies: 3Last Post: 18th Aug 2008, 10:59 -
Downgrade your PSP to version 1.5 using your PSP battery
By chrise in forum Newbie / General discussionsReplies: 1Last Post: 20th Dec 2007, 08:27 -
Nero 8 Recode to PSP - No Title on PSP?
By sonicm in forum Video ConversionReplies: 1Last Post: 6th Dec 2007, 14:13 -
.wmv file to psp for a mac
By melacanth in forum Newbie / General discussionsReplies: 0Last Post: 3rd Aug 2007, 22:43
