    Jan 2005
    i want to extract .vob files from my dvd to my harddrive and i wanted to make the .vob's into one .avi how would i go about doin this? thnkx
    dr. divx, autogk,vidomi or virtualdub-mpeg2 if you want to make divx, xvid avi or dv avi.
    https://www.videohelp.com/guides.php?guideid=759#759 if you want to do some advanced editing or use mpeg video wizard.
  3. I use DVDx to extract VOB files from a DVD and write them out as MPEG files. I don't remember whether it can also do AVI.
  4. Originally Posted by shira
    Yes it can.
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    You know the Convert section left? Take a look under "DVD to AVI"...
    /Mats
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    /Mats
    Now there's a novel concept ...
    There's many different ways, many different softwares that will integrate all the steps for you such as any of the tools listed here, or alternatively if you know what you're doing or have a good guide then you can do each step manually. There's quite a number of guides listed here also.
    If in doubt, Google it.
  7. Use DVDDecrypter to extract VOBs. Select "No Split" so that you get one big VOB. Then use VirtualDubMOd to convert VOB to AVI.
    Read the "How To" section for more details.
    When I was born I was so shocked that I could'nt speak for 18 months.
