Hi,
I keep getting this error after I run RC6.
Title Program Chain Table: End Address 305 doesn't match table size 214 (c:\workplace\IFOL U_IFO.pas line 4848)
I am completely clueless on this. Because that directory doesn't exist.
So is this a setting problem I am having or an installation problem? Please help.
Steve
Results 1 to 12 of 12
How are you trying to burn your DVD?
I am sorry the error says it 'doesn't match table size 314' not 214 as I previously posted
So are the VIDEO_TS files created by SVCD2DVD?
So the VIDEO_TS folder is created? It plays ok on the computer? But when you try to burn it - you get this error?
They are compliant if the authoring is succesful.
Can you guys try RC8? If you get the same issue i will need some further details. I have some test files which will create a small DVD. We can try those & you can send me the VIDEO_TS folder for analysis.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Will the created BDMV burn correctly and start at the beginning?
By pepegot1 in forum Blu-ray RippingReplies: 2Last Post: 5th May 2011, 07:37 -
removing background noise in AVI files created from .MOV files
By p_s_92 in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jun 2010, 08:26 -
H.264 TS files created using HD PVR to MKV.
By Red Hat in forum Video ConversionReplies: 223Last Post: 19th Nov 2009, 15:35 -
Making a DVD menu from .VOB files created by FAVC?
By whatever911 in forum Authoring (DVD)Replies: 9Last Post: 16th Feb 2009, 03:13 -
How are ifo files created with only vob files?
By Han Solo1 in forum Newbie / General discussionsReplies: 0Last Post: 18th May 2008, 13:07
