Hi all,
I downloaded 2 .avi files and tried to join them with vdub.
Upon opening each individual file within vdub I got an error indicating that "improper VBR audio encoding had been detected and will rewrite with standard CBR values".
I ignored this and tried to join them. I got an error saying that it cannot join them because they are at "different sampling rates"
To get round this I ran the two files seperatley through vdub with full audio processing mode and compressed the audio so that they were all the same (i picked MPEG layer 3, 128 kBit/s. 48.000 Hz stereo).
So then I took the new files and tried to join them.
The 2 files are 20 mins long but when I looked at the result of joining file 1 to file 2 the result was a file over two hours long which had repeated itself twice and I also noticed all the dubbing was out the further into the file I looked.
What the hell am I doing wrong????
Results 1 to 11 of 11
Click YES, when prompted with the error.
Don't compress audio.
Learn how to frameserve, unless you just want to join these for storage.Cheers, Jim
My DVDLab Guides -
It sounds to me like the filenames of the videos were the same with numbers at the end. Like "Video1.avi" and "Video2.avi". When numbered this way, when you load Video1, VDub will automatically appended video2. and then you appended Video2 again. I don't think it always does this depending on the version of VDub you have, but if you're not aware of this feature it can be really confusing.
Buy My Books -
Thanks gadetguy I will try your suggestion out.
Thanks also to reboot but can I ask what you mean when you say learn how to frameserve unless you just want to store them. My purpose for these two files is to combine them and then put them on a DVD to watch on my TV. I do not need to alter or play with the quality in any way, so is the method im using the correct method or is there a better, quickier and easier way. I will use TMPGEnc and TMPGEnc Author for the latter stages after the .avi files have been combined using vdub -
If your aim is to convert the files to DVD mpeg2files you don't need to join them before conversion. This can be done after the conversion at DVD authoring step.
If your aim is to play the avi files in DVD player or TV VDub is the solution to join them.
Simply nobody knows what you want. -
Where you download them from and why you tried to join them?Originally Posted by wuzzbert
Hi all and thanks for your help.
The files are two recordings of a new band and I downloaded them off their website (perfectly legal may I add!)
All I wanted was to have them on one dvd disc, so I could play them on my dvd player connected to my tv.
I'm no expert as you can tell but read a few 'how to guides' and decided I needed to join the files and then convert them and then author them using tmpgenc and TMPGEnc author
From reading your responses it seems a better way would be to join them at authoring stage, is this correct? If so how do I do it
Thanks all -
If you're going to use TDA, just add both videos when prompted.
Cheers, Jim
My DVDLab Guides
I think Im missing a few things
By craigarta in forum Video ConversionReplies: 4Last Post: 21st Aug 2011, 09:00 -
Things have changed
By Marco33 in forum Off topicReplies: 13Last Post: 23rd Dec 2010, 22:29 -
First Things First
By vusamoyo in forum ffmpegX general discussionReplies: 1Last Post: 31st Jan 2009, 05:53 -
Help, I think I am going crazy
By pfxz in forum Off topicReplies: 6Last Post: 3rd Aug 2008, 10:17 -
trying to do 2 things at once
By AMGvh in forum Newbie / General discussionsReplies: 4Last Post: 17th May 2008, 20:55
