    Oct 2002
    INdiana
    My HP laptop came with WinDVD and i want to put it on my desktop but when i go to install it, it comes back saying its not a qualified HP machine. Any way around this?
    USA
    If you mean you want to install it on a different computer, then no, probably not. It is likely set up for OEM installation only. Many programs that come bundled with computers and DVD drives will only work with the particular drive or machine that it was configured for.
    Get a retail copy if you want to put it on a different machine.
  3. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Yep hard to do if it is possible. Just easier to buy a legit standalone copy of the player software.
    OR try ebay for a used copy - or get an older version discounted at Best Buy or Circuit City....
    Kevin
  4. I got a copy of WINDVD when I bought a dvd curner a while ago.
    Oct 2002
    INdiana
    is there a free version of a dvd player software out that you recommend?
  6. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    I don't think anything's really 'free' because there are royalties to be paid.
    Nothing can stop me now, 'cause I don't care anymore.
  7. Mod Neophyte redwudz's Avatar
    USA
    For free, you can try VLC Media Player. Very versatile. But if you want a program that is optimized for easy DVD play, either PowerDVD or WinDVD are good. But they are payware.
  8. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    I would prefer PowerDVD. However, another freeware would be zoom player.
