Im using DVDlab Pro and I need some help setting up chapters in a menu. What I have is many movie files, seperate anime episodes, that I want to be seperate chapters.
I dont see how to set that up. I found a template for the scene selection menu i want, but for each image i want that to be each episode. I loaded up all the files into the asset box and made each episode a seperate movie. how do i set the menu up so each movie is a chapter and shows up as such in a scene selection menu. Thanks
Set a chapter point manually, at the end of each episode. Generate the menu.
Cheers, Jim
My DVDLab Guides -
ok , thanks.
i did notice that i could jsut drag each movie onto the menu and make menus for as many movies i wanted on each page. that satisifed what I wanted. -
If you have a lot of seperate clips, and you want to be able to move from clip to clip using the next button, then do as Reboot says. Add a chapter point at the end of each clip. In the Connections window link each movie in sequence. Keep your menu as you have it, so you start at the beginning of each clip. When you hit next, you will jump the end of the clip, then move straight on to the next clip.
Read my blog here.
missing chapters on standalone dvd - dvdlab
By lukasz.w80 in forum Authoring (DVD)Replies: 0Last Post: 10th May 2011, 09:56 -
Authoring with DVDLAB 1.3 and chapters get out the farther I go!
By gwoiler in forum Authoring (VCD/SVCD)Replies: 5Last Post: 28th Feb 2010, 17:18 -
Reliability of DVDLab Pro 2
By Brainiac in forum Authoring (DVD)Replies: 2Last Post: 28th May 2009, 18:04 -
Setting the layer break on a DVD9 (DVDLab Pro project)
By lorix in forum Authoring (DVD)Replies: 4Last Post: 13th Nov 2008, 11:19 -
make my own default setting in dvdlab pro ?
By pcb in forum Authoring (DVD)Replies: 0Last Post: 13th Mar 2008, 14:21
