Hi, I am using an Apple iMac G3 with an NEC 3520A DVD-+RW drive with Toast 6 on OSX 10.3.8.
My problem is that when burning any kind of disc wether it be a CD or DVD, the clock counter does not run down at the correct speed. As an example when burning a CD on x48 (it does not matter what speed i burn on) the clock counter will say 2 minutes but for every second that passes on the clock about 5 seconds pass in real time. So instead of the CD tacking 2 minutes it is actually takeing 5x longer.
I bought this drive because of its speed, so you could imagine my frustration when i came across this problem. Any help from anyone would be most appreciated.
Thanks.
Results 1 to 1 of 1
DVD exploding inside the drive from a drive exceeding 24x. True?
By snafubaby in forum MediaReplies: 10Last Post: 5th Dec 2010, 19:05 -
CANON FS10 poblem
By MJ Kubicki in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 21st Sep 2010, 17:31 -
Toast 9: The drive reported an error
By soundchaser in forum MacReplies: 16Last Post: 1st Jul 2009, 15:55 -
Time/Date Stamp - DVD, Hard Drive, and/or flash drive camcorders
By vanjh9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 2nd Feb 2009, 19:38 -
Guide to fix Illegal Disc Error for NEC drive (possibly others)
By lucaschrist in forum DVD & Blu-ray WritersReplies: 10Last Post: 5th Apr 2008, 02:11
