Hi! I'm posting this after having searched for quite some time on this forum not having found a solution for my problem. So here it is: there’s no way I can capture using HuffYUV, but this comes out really strange. When I install version 2.1.1, it does not appear on my available codecs for compression on VirtualDub capture thus I can use it to compress files afterwards and works perfectly. When I install version 2.2.0, it appears on the available codecs for capture on VirtualDub and it does, BUT the resulting avi can not be used anywhere: even VirtualDub crashes immediately when I open the avi and it gives this error message
An out-of-bounds memory access (access violation) occurred in module 'huffyuv' while decompressing video frame 0 with "Huffyuv v.2.2.0" [biCompression=55594648] (VideoSource.cpp:1772).
I actually found two topics that can rely to my two problems:
https://www.videohelp.com/forum/viewtopic.php?t=249871&highlight=huffyuv+virtualdub
and
https://www.videohelp.com/forum/viewtopic.php?t=258247&highlight=huffyuv+virtualdub
Note that none of them solves the problem, that surprises me as in the most parts of topics problems are usually solved! In the first one noone has understood what the guy was asking, in the second the advice to employ Codec Sniper simply doesn’t get to the point.
Is anybody able to put an end to these problems??
Thanks to anyone who’ll try to help
I can't believe that really nobody can help me with this
Anyone?? -
If memory serves me correctly..
In one of the revised versions, it had a BUG in it (UV or something) and
it would not work properly when frameserved, etc.
The simple answer to your question is this. Delete that file you captured,
(since you say you can't view it) and start over, by re-capturing it again.
* But, first uninstall the current huffy codec you have now. Device Mananger.
You should see a (remove only) next to the huffy codec line.
* After removing, REBOOT.
* Now, install a non-bugged version of huffy. perhaps the one you used
previously, that worked for you.
-vhelp 3245
I have a strange problem and I would like to ask if is possible to be solve
By takis76 in forum SubtitleReplies: 1Last Post: 8th Dec 2010, 15:53 -
How do I solve this file joining problem?
By A_Shepherd in forum EditingReplies: 30Last Post: 2nd Sep 2010, 14:27 -
Can you solve my choppy video problem?
By imrealdumb in forum Newbie / General discussionsReplies: 2Last Post: 4th Jun 2009, 21:44 -
Installing ffdshow to solve codecs problem?
By giunghi in forum Newbie / General discussionsReplies: 11Last Post: 22nd May 2009, 06:42 -
Unable to solve a boot problem, really need some HELP.
By blinky88 in forum ComputerReplies: 5Last Post: 24th Apr 2009, 17:17
