Results 1 to 18 of 18
  1. Banned
    Dec 2004
    SE4
    People say theres no degradion in digital media.
    When i get bad sectors and corrupted data will it still not be degraded (the video playback) but i will get freezes and easily noticeably blocky screens..
    Thats not really degradion though isit becuase degradion is something wearing out but when data is corrupted its not worn out i suppose isit..
    Am i right here?
  2. Banned
    Dec 2004
    SE4
    cheers for your help
    Ive seen these vids i got, and theres blotches of green on some bits, its XviD i then got it on another compouter from the internet and its exactly the same playback, there are blotches of green and some bits go really pixelated as if it were a bad drive.. This must have been a bad encode, right or something the other persons end damaged them??
  3. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    AVIs "found" on Internet, and specially on P2P networks, where IMO KaZaA stands out as the worst example, are to a very high degree ridden with data errors, some to the point where (parts of) the video won't play at all. If the source you DL from is equally bad, or bits&bytes get damaged/mixed up in the transfer, you'll never know, until you can compare the file data side by side.
    /Mats
  4. Banned
    Dec 2004
    SE4
    Well we all know kazaa is a pile of poop lol i stopped using that at 13..
    So these downloads i get will they corrupt on their own or will something make them corrupt llike a hard drive corruption??
    Also i put something on cd ages ago, watched it on the tv and pc from the cd and it was jumpy, copied it back, watchedit once it had been copied back and it wasnt jumpy at all, why was it jumpy??
    where u said 'some to the point where (parts of) the video won't play at all'
    did u mean they will eventually be so errored that they wont play at all??
  5. Mod Neophyte redwudz's Avatar
    USA
    Generally, once the downloaded file is on a HD or DVD, there will be no more deterioration. You will just have to deal with the screw ups that came through poor original encoding and transfer defects. You can't recover lost data.
    You can cut it out, but you usually can't fix it. An old CD file may have been put on poor quality media, which can deteriorate. Had that problem myself. Don't use crap media and you will have less problems. You probably use different codecs now than you had then, that makes a difference also.
  6. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Yes, not at all. If vital bits of the AVI has the wrong value or are mising altogether, the player (and/or codec) can't decode it at all.
    Or "bad frames" present in the AVI which makes it unreencodable (but probably still watchable).
    /Mats
  7. Banned
    Dec 2004
    SE4
    Cheers.
    What can cuase movies to go out of sync, name me all the things.
    If i have a corrupted hard drive can that make sound go out of sync on videos on it but wld i always get a freeze or wld i sometimes not get a freeze and sound wld be out of sync..??
    where u said 'You will just have to deal with the screw ups that came through poor original encoding and transfer defects' does that mean if i DO download an errory type file over time this file will get worse well i suppose it wont actually cos its on the hard drive and cant deteriorate am i right yeah?
  8. Banned
    Dec 2004
    SE4
    AAh right, so if i do get a dodgy download its defoinate after time it will get worse for no reaosn what so ever?
    So i get a download with say 4 blocky bits on it.
    The drive has been kept in good health with same codecs and i have it on there for about 1 year ru saying that out of the blue the film will randomly get more errors on it as time goes on??
  9. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Jason, Listen closely: Data don't go bad. Media (what the data is stored on/in) might.
    Bad encoding.
    No. No, like in "Will you be hit by lightning the next time you ask a question about digital video file degradation?" I guess it could happen in theory, but the probability is so low, we don't have to take it into account, even as a academic question.
    /Mats
  10. Banned
    Dec 2004
    SE4
    lol no worries man i juss get so stewed up about nothing lol its kinda an obsession with me i suppose honestly you lott have been really helpful n irespect u all 4 this, ive learnt so much being on these forums now.
    where u said this
    'Yes, not at all. If vital bits of the AVI has the wrong value or are mising altogether, the player (and/or codec) can't decode it at all.
    Or "bad frames" present in the AVI which makes it unreencodable (but probably still watchable)'
    So these issues wld be as soon as the download completes on the hard drive caused from a dodgy transfer??
  11. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    NO! it will be exactly the same until what it's stored on/in starts losing bits and bytes.
    /Mats
  12. Banned
    Dec 2004
    SE4
    And how could it start losing bits and bytes what would be the cause of this mate?
    sorry
  13. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Yes. And the day after. And year. And decade. And century.
    /Mats
  14. Banned
    Dec 2004
    SE4
    so youre saying that if a transfer goes wrong and i have corrupted data from it it wont get better it wont get worse it will stay like it on the drive forever with no degradion.
    Obviously bad sectors wld damage it more but all being a healthy drive the corrupted download will stay how it is for ever n ever..lol
  15. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    And how could it start losing bits and bytes what would be the cause of this mate?sorry
    Aww geesh! Why did I eve... Ah, well, writable media like CD-R and DVD-R and stuff do have a live span. They are simply not resistant to the tooth of time.
    Hard drives store the bits and bytes on a magnetic surface - hold it near a magnet, things start to happen with the data stored on it. If a velocitron, emitted from the Sun, hits the wrong electron in your HDD and brings it along on its voyage to eternity, a "1" in a byte somewhere in your AVI encode of Lost In Translation turns into a 0, and Voila! At frame 23456 there's a green pixel where before, the glint in Bill Murrays Whiskey glass was.
    Things go bad over time. Data doesn't. Now, this is starting to get more of a philosophical question - what is data without its storage medium? I suggest you start reading some of our great Cyber Punk writers if you've not done so already - like (early) Neal Stephenson and William Gibson. If nothing else, it will keep you absorbed for a while...
    /Mats
  16. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    100% correct. There is still hope!
    /Mats
  17. Banned
    Dec 2004
    SE4
    sorted then thanks very much for your help..
