i need some help with a question ya can any body help me and explain it to me like i'm a 6 yr old
1. I downloading movies right and I brought these disc (CD-R, dvd+r, and dvd-r) I burned a movies on to the CD-R and it worked but not on my dvd player my friends dvd player so I brought dvd-r and dvd+r so they can work on my dvd player. So my question to u is i have to format the dvd-r and the dvd+r and i don't know how to do that can u please help me or can u direct me to where i can get help. i use nero 6.6 and TMPGENC DVD AUTHOR and my tmpgenc is not working right it keeps on freezing or not responding i may have to redown load that but if u can help me i appreciate that thank you.
Results 1 to 13 of 13
You don't format DVD-R or DVD+R. You need to erase DVD_RW and DVD+RW.
If you downloaded a Divx movie and burnt it to CD-R then it will not play unless your friends player can play Divx movies.
I think you need to start reading some of the guides in the How To section (found on your left). Especially in the AVI to DVD area.Read my blog here.
Are you absolutely positive you have a Sony DVD burner in your computer?
Cheers, Jim
My DVDLab Guides -
THANK YOU GUNS1INGER FOR ANSWERING MY QUESTION AND DIRECTING ME TO GO TO THE HOW TO SECTION.
YES I'M SURE I HAVE A SONY DVD BURNER ON MY COMPUTER. ITS JUST THAT I HAVE THESE DISC (DVD-R & DVD+R) AND I DOWNLOADING A MOVIES AND I WAS USEING NERO TO BURN THE MOVIES ON THE (DVD-R & DVD+R) AND IT WONT COPY. DO ANY BODY KNOW WHAT I HAVE TO DO.
Convert (encode) your avi to mpeg-2, then author and burn.
Start with the Guides section, look for "AVI to DVD".
More here: http://members.shaw.ca/videojunk/avi2dvd.htm
http://members.shaw.ca/videojunk/all.htmCheers, Jim
My DVDLab Guides -
REBOOT I'M NOT TRYING TO BUG U AT ALL. BUT HOW DO U CONVERT (ENCODE) MY AVI TO MPEG-2 IF U DONT MIND ME ASKING. THANK YOU
Please stop typing in CAPS which means you're SHOUTING. It is rude to type with your CAPS LOCKED. The guides section on HOW TO CONVERT is over to your left<<<<<<<<<<<<<. Do a search or read the guides before posting questions.Originally Posted by therinrnb1
oh I didn't know about the caps. I'm looking at the how to section its just kinds had to look for the right information.
first off, you need to find out exactly what kind of file you are starting with. find out what kind of file it is you downloaded. then you need to realize that if you want to make that file into a dvd (-r or +r doesn't really matter) that it has to be in the correct format. for dvd you need to convert whatever type of file you downloaded into an MPEG-2 file. then you need to use a dvd authoring program like dvd-lab or tmpgenc dvd author which will put your MPEG-2 file into the correct format to burn onto the dvd. ANY dvd you look at will consist of VOB files. these are what your dvd player reads. they are really just MPEG-2 files with the names changed to be read by a standalone dvd player. go the guides section and look how to convert whatever file type you have now to a dvd5, which is a normal recordable dvd. there will be many guides there telling you step by step how to do this.
now we've given you just about all the information we can without actually making your dvd for you. use the guides section of this site. that's what the guides are there for. i learned everything i know from this site and i started from scratch. you can do the same. it just takes time. -
Most home DVD player plays VCD (VCD and SVCD) and DVD (DVD-r or DVD+r). Some older DVD players will not play SVCD or DVD+r. Only special players will play DIVx.
I think most downloaded movies are in DIVX format ( not sure if I am right).
DVD-r and DVD+r are determined by the media that you bought. You cannot format it. Most newer DVD writers can write DVD+r or DVD-r. However there are still DVD writers out there that only support one or the other.
I have two DVD players and one does not play DVD+r. So I always burn my DVD on DVD-r disks.
If your download movie is in DIVx format, you can use vsoDivxToDVD to convert it to DVD fomat before you burn it to a DVD disk. -
I agree with the first post. Do some reading and quite asking for your hand to be held at each step. Determine first what your source file is. Then decide what you want to do with it, convert to MPEG? This is not a click the pretty button hobby. No one step solutions here.
ID the source file
Convert to MPEG format as needed (DVD compliant one)
Author
Burn
Watch on tv
Lots of reading:
https://www.videohelp.com/guides
http://www.digitalfaq.comWant my help? Ask here! (not via PM!)
Help Converting an ISO Image File into a DVD Format playable on DVD players
By Gradyj in forum Newbie / General discussionsReplies: 5Last Post: 19th May 2010, 21:13 -
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 13:12 -
Samsung dvd-4155 DVD Player/recorder format problem
By jamesd1 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 20th May 2009, 23:51 -
Hi8/Video8 to DVD...to editable format...back to a DVD with a menu!
By lornarose in forum Authoring (DVD)Replies: 14Last Post: 8th Nov 2008, 17:03 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 09:21
