i've got a folder with dvd9 files (vobs/bups/ifos), i want to extract those vobs to a huge mpeg2 file. it only has one audio track (ac3), no subtitles.. very basic dvd.
i just want to extract it to one gigantic mpeg 2 file with ac3 audio.
i tried using tmpgenc mpeg editor, but it keeps splitting it up by each chapter.. so then i tried deleting all the chapters with ifo edit.. no luck..
i dont want an m2v & an ac3 file, i want one ready muxed mpeg file.
i'm sure this is probably easy to do, i've search and couldnt find anything. i'm sure the solution is so simple i'll want to smack myself one.
Results 1 to 9 of 9
If in doubt, Google it.
ReJig.
/Mats -
nope.. tried all of those yesterday.. there is a method to doing it that i've devised.. i just figured there might be an easier way..
rip to files w/ dvd decrypter, use tmpgenc mpeg editor and output to mpeg files (one per chapter), author to dvd files in tmpgenc dvd author (no chapters), use tmpgenc mpeg editor to output to one big mpeg file..
i was just hoping there was a way to output the dvd files to one bigass mpeg without going through all those steps. -
okay. i figured it out.
i imported the vob's in to womble mpeg video wizard an i was able to export as an mpeg file. it was very easy to do.. instead of going through a bajillion steps -
Originally Posted by lumisThere are 10 kinds of people in this world. Those that understand binary...
i tired the one huge vob file, didnt work.. but i've got anydvd running, so from now on when i need a huge mpeg file from a dvd i can just drag the vobs from the disc to womble mpeg video wizard & create the mpeg straight off the disc.
thanks for all the help -
... or if you have Nero Vision Express.
Load the VOB file in NVE. After some procesing NVE will be ready to export the file to whatever format you choose. Dont export. Goto MyDocuments > NeroVision > Imported Video. There you will have your MPEG file with same settings as bitrate, aspect ratio, audio etc. Only it will be in MPEG not VOB.When I was born I was so shocked that I could'nt speak for 18 months.
AVI files make DVD huge
By dishwater63 in forum Authoring (DVD)Replies: 6Last Post: 13th Dec 2010, 19:09 -
Making XVID videos with VirtualDub: output files w/huge file sizes (~1GB+)
By maskingtape in forum Newbie / General discussionsReplies: 11Last Post: 4th Mar 2010, 23:50 -
Help me reduce these huge video files! How does the "scene" do it
By AnitaPeterson in forum Video ConversionReplies: 10Last Post: 9th Dec 2009, 18:32 -
DATA files rather than MPEG files from a DVD-Video?
By DieselsDen in forum Newbie / General discussionsReplies: 11Last Post: 14th Dec 2007, 03:24 -
Huge avi files in Virtual Mod
By KayAt in forum Newbie / General discussionsReplies: 3Last Post: 25th Oct 2007, 19:08
