I recently borrowed a small MPEG4 video camera from a freind. The camera stores its videos in ASF format on the little SD card inside. Now Windows Media Player plays them fine because it downloaded the corresponding codec for itself. However the files cannot be opened in Movie Maker, Premier or any other conversion program i have tried.
Below is a link to a short 272K clip from the camera.
http://au.msnusers.com/Shpomp/Documents/IMAG0039.ASF
If anyone can help at all it would be greatly appreciated.
Cheers
Nick
Results 1 to 19 of 19
Hi Nick,
Your link doesn't seem to be working.
https://www.videohelp.com/tools?toolsearch=&s=&orderby=Name&hits=50&convert=ASF+to&dvda...+or+List+tools
You can search the tools and the guides section by format conversion - this is a link to all the ASF --> ??? tools. Also, you might want to take a look at VirtualDub ASF, which can be found near the bottom of this page:
http://www.digital-digest.com/dvd/downloads/showsoftware_virtualdub_346.html
VirtualDub is like a Swiss army knife when it comes to video editing and encoding. You can use it to convert to whatever you like, or to frameserve the ASF into a program like TMPGEnc to make a DVD-compliant file.
Hope this helps!
Cobra
PS - Welcome to VideoHelp! -
thanks for the reply, i have tried VirtualDub only to be faced with a notice stating that microsoft owns the patent to .ASF files and intercompatibly isnt a frequent occurance.
There are many different "flavours" of virtualdub - and virtualdub 1.3c will stll accept ASF files.Originally Posted by rustbucket
I see it written as and linked to 1.4c all the time
Here's a genuine link to 1.3c:
http://www.afterdawn.com/software/video_software/video_tools/virtualdub_1_3c.cfmIf in doubt, Google it. -
I don't use ASF files. I didn't realise that 1.4 didn't do it - I found a version that says it supports ASF and linked to it.
It's something that I see a lot of, as I said. In fact, I think HRH (Baldrick) has made the same error in the Tools section here. I've mentioned it to him, but it fell on deaf earsOriginally Posted by Cobra
Version 1.4c comes up with the "Microsoft nows owns the patent on ASF files ...." spiel, whereas 1.3c just opens 'em up without a hassle.If in doubt, Google it. -
i tried to import the asf into the version you just gave me and i was given this.
[img]http://groups.msn.com/_Secure/0OgAPA3wQrMtaUzOCUd7x!pgrkgxx4RyEPtm9FGlIv2bUBK23n KMXWWNZdY1SNezsIa8MimGvhw*8UHaTY!uB4sFruEW0QwdE/d.JPG?dc=4675514741434151218[/img]
any ideas? -
so ...... 1.3c did the job ?Originally Posted by rustbucket
EDIT:
OK, at least it got past the patent issue message ...
... sounds to me like it uses a proprietary codec or something ... have you tried the camera manufacturer's website for the codec ?If in doubt, Google it. -
it works fine playing in media player, it had to download the codec but after that its fine, can you access the file at the end of the link i put in my first comment?
id be very grateful if you could see if it works with your setup -
I can't get to the file either (not authorized)
I tell you what ...
put the entire next line in your next post:
[*url]imag0039.asf[/url]
(but without the * - just put it there for demonstration of the bbcode required)
... then click on the Browse button and browse to your ASF file (you can upload files up to 2MB in size this way), then hit submit.If in doubt, Google it. -
I got the same error you did in virtualdub 1.3c, but I could open it no worries in Windows Movie Maker and TMPGenc Plus.
when i try to open it in Movie Maker all i get is
C:\My Shared Folder\Digicam\Bowling in Melbourne\IMAG0021.ASF could not be imported. The selected file is not valid or is corrupted.
i also get the same with TMPGenc
"cannot open file or is unsupported"
EDIT: i have TMPGenc Plus 2.5, could it be i have the wrong version? -
in TMPGEnc, do you get the "cannot open, or unsupported" error message ? If so, try raising the priority of the DirectShow Multimedia File Reader so that it's at the top of the list. You can do this in Options > Environmental Setting > VFAPI Plug-in, then right-click on it and go to Higher Priority. Repeat this if necessary until it's at the top and make sure that it's ticked.
nah, still get the same message
p.s i really appreciate you helping though thanks -
ASF to MOV or MPEG4 problems using FFMPEGX for Mac
By Maverick101 in forum ffmpegX general discussionReplies: 3Last Post: 29th Sep 2011, 13:54 -
Encoding .DV problems with ffmpeg (e.g. MPEG4 -> DV or VOB -> DV)
By AlphaMonk in forum ffmpegX general discussionReplies: 1Last Post: 23rd Feb 2010, 05:24 -
Mpeg4 to ?
By acestu in forum Newbie / General discussionsReplies: 6Last Post: 29th Jul 2008, 22:45 -
Mpeg4 hd size
By brandensky8 in forum Newbie / General discussionsReplies: 1Last Post: 21st Nov 2007, 23:35 -
Getting DVDs to MPEG4-SP or MPEG4-AVC
By WoWchamp in forum DVD RippingReplies: 7Last Post: 31st Oct 2007, 00:47
