Well, what a day! I was using the same Maxell 8X DVD-R (knock knock MADE IN JAPAN) which I've been using with no problems, and suddently 8 coasters in a row.........I tried uninstall/re-install Nero which made no difference and finally switched to Verbatim and problems solved!
How likely is it to have a bad batch of discs in a 50/pk?, the first 15 discs were all burned OK with no problems...but from disc #16 till #23 they were all BAD! Called up Maxell and they asked me to send them back for warranty replacement! men....![]()
It is not impossible for something like this to happen. At least they offered to replace the faulty discs.
Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think. -
Thanks Skith, I guess I just couldn't accept the fact that most people believe discs made in Japan are superior than those made else where (including myself), and see what happened, no coaster yet with Sony's and Verbatim's (both made in Taiwan) and having 8 coasters with Maxell's (made in Japan)...
No matter how good some discs are, you're bound to run into some bad batches sometimes or another.
or writer compatibility
we are assuming here that the computer has been flawlessly burning DVD before?
Is it already 2012? The Detroit Lions win 3 in a row?????????
By yoda313 in forum Off topicReplies: 1Last Post: 27th Dec 2010, 12:07 -
HP DVD+R coasters...
By lost123 in forum Newbie / General discussionsReplies: 10Last Post: 18th Nov 2010, 16:48 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48 -
Getting coasters with Nero 7???
By dagerousdave in forum Newbie / General discussionsReplies: 2Last Post: 30th May 2007, 20:12 -
How to get rid of Windowboxing on a DivX file for Front Row
By hauns in forum MacReplies: 0Last Post: 9th May 2007, 14:44
