I downloaded the latest version ,After i make a mpeg from a bin.Then remultiplix.changes it from pal to ntsc I burn it to dvd the audio comes in out in the whole movie
Does this happen when you play the VIDEO_TS folder on your PC with your software DVD player?
It works when I view it on the program but when i burn it to dvd the audio starts then goes out
I dowmload the version rc-7.Am having the same problem .It works fine till it burns the dvd,the audio starts then goes out,and comes back later,though the whole movie.All the other version worked fine but not the last two 6,7
Do you want to email me your logs for the issue?
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 11:25 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 17:24 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 04:12 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 01:19
