I am using the Rockas DVD-RB v0.77 installer version w/ Cinema Craft encoder 2.70 trial. I am using the default settings with CCE set to 6 pass. My finished product shows 30- 80% of the screen with green pixels on it as it plays throughout the entire movie. I have had success with DVD-RB v0.70 w/ CCE 2.5 SP in 3 click mode but cant figure out this problem. Does anyone know where I went wrong?
Results 1 to 10 of 10
If you look like food, You will be eaten.
Did you rip the DVD to your hard drive properly? As in, did you decrypt the disc when you ripped it?
The disc was ripped with the newest version of decrypter. It was ripped to an image and mounted with Daemon Tools. Have tried several discs to backup and have the same result with the green pixels. CCE trial was checked.
If you look like food, You will be eaten. -
As far as I know Rockas v0.77 installer installs and configures eclCCE. CCE encodes the entire movie with out me having to point out the next file in CCE's gui. I just can't figure out the green pixels. Output fiile size is correct also. Sorry about the long reply times, I have no web at home and have to use the office's connection. Thanks to all who have replied so far.
CCE SP 2.70 does not need EclCCE to work.
The CCE NEW path in RB setup must be pointed to the CCE executable (ccesp.exe), not to EclCCE
If I undestand correctly you start having this problem after upgrading to cce 2.70. And this problem is present in ALL backups you have tried since then. Am I right?
Please verify you are using the original CCE 2.70 Trial version (the one that put a Cinema Craft Logo in your encoded video. If not, download and install a new Trial copy from Cinema Craft site (in fact this could be a good idea anywhere, as the copy of your encoder could have a problem)
Other: Have you messed up with the Advanced settings in CCE Options? Your source have just been ripped and nothing else before processing with RB, or have you do some pre-processing?Newbie to DVD backup -
Nevermind I'm too inept to be here. Thanks to all who attempted to fix my problem
bd-rebuilder problem
By mathbes in forum Blu-ray RippingReplies: 3Last Post: 12th Feb 2012, 04:15 -
BD Rebuilder new version problem
By fazza8 in forum Blu-ray RippingReplies: 5Last Post: 20th Aug 2009, 06:36 -
BD Rebuilder 22.01 Problem
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 2nd Jun 2009, 13:36 -
Problem DVD Rebuilder Pro: Is not a ECL for CCE SP Trial Version
By Talayero in forum DVD RippingReplies: 2Last Post: 30th May 2008, 13:25 -
problem with dvd rebuilder!
By jonkiller in forum DVD RippingReplies: 1Last Post: 2nd Aug 2007, 08:58
