Normally when i get a movie, i don't watch it on my computer 'cuz it's too uncomfortable, so i burn them...lately i have just been getting one .avi file and converting it to dvd files...but i have a couple movies that are split into cd1 and cd2 avi files.
is there any way i can merge the two so they are 1 and they burn correctly? or if i just put both files in nero ultra eidtion..6 or whatever, will it work? please help, asap.
no. vdub isn't authoring softwareOriginally Posted by justinbhughes
convert to DVD-compliant MPEG-1/2, then use TMPGEnc DVD Author or your favorite authoring software (the software that takes your MPEG files and converts them into IFOs, BUPs and VOBs for you) to join them.If in doubt, Google it.
Merging files
By drtbray in forum EditingReplies: 12Last Post: 13th Apr 2012, 16:08 -
Merging avi files with subtitle and aac soundtrack
By kurian in forum Video ConversionReplies: 5Last Post: 31st Jan 2011, 02:52 -
Problem in merging splitted AVI files of a movie into one.
By nick2712 in forum Newbie / General discussionsReplies: 8Last Post: 2nd Oct 2010, 14:20 -
Quality problems after merging two .avi files
By Metallo in forum EditingReplies: 14Last Post: 13th Aug 2008, 09:50 -
Problems with merging to avi files
By mingul in forum Video ConversionReplies: 3Last Post: 6th May 2007, 10:06
