Is there a good way to convert an audio format to a mono WAV with specs 11025Hz, 8-bit and in mono? I'm creating subtitles using Sub Station Alpha and for timing, they require the WAV to have those specs. The current way I'm doing this is to use BeSweet to convert to a stereo WAV and then use Window's Sound Recorder to convert to those specs. That's the only program I know that has those specs. The programs I have are Audacity, BeSweet, Cool Edit Pro and Goldwave. The problem is that for long WAV files, it takes incredibly long to open in Sound Recorder so I'm looking for a faster option. Any suggestions?![]()
5.1 wav or 6 mono wavs to 5.1 Ac3 conversion
By wturner in forum AudioReplies: 38Last Post: 24th Nov 2013, 08:26 -
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 13:36 -
6 mono Wav to ac-3 or other?
By dave_van_damme in forum AudioReplies: 6Last Post: 18th Dec 2008, 19:55 -
Converting a Mono Left Channel to Double Mono Left/ Right Channel on a DVD
By socool135 in forum AudioReplies: 5Last Post: 16th Sep 2007, 00:45
