...get a better burner !
i was going crazy because my LG player would skip on my DVD's which i burned with a Samsung TS-H542, yesterday i got a NEC 3520, mainly because i wanted to use the DVD+R to DVD-ROM booktype.
as a test i made another DVD-R the same way i did with the old samsung, same media, same speed.... no skipping !
thanks NEC.
Sometimes its the media that makes a difference with the burner,one burner will love ritek for example but another make of dvd burner will burn coasters with it.
johns0 is correct that 'good' discs will be 'bad' discs on another burner. The great thing about NEC burners is just about anything you put in them burns well, including alot of generic media that my other burners will refuse to even burn. NECs are very tolerant of different types of media.
DVD skipping on certain players...
By Lewshu in forum Newbie / General discussionsReplies: 1Last Post: 6th Jun 2011, 00:35 -
DVD skipping for Client - tried everything we can think of!
By trevmarps in forum Authoring (DVD)Replies: 15Last Post: 2nd Apr 2010, 16:46 -
Skipping a menu on a DVD
By Luriden in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2008, 23:03 -
DVD keeps skipping!
By Variable in forum Newbie / General discussionsReplies: 6Last Post: 21st Jun 2008, 19:05 -
DVD Player Skipping
By WuPhilly in forum Newbie / General discussionsReplies: 4Last Post: 12th Jun 2008, 11:33
