  1. I am trying to find out what is the difference between the 3 Nero OEM Suites. Is there a way to tell from the CD content which one is suite 3?
    THANKS
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    look at the version #
    Google is your Friend
  3. The version I have is 6.3, but its OEM. So I am trying to figure out if its Suite 1, Suite 2 or Suite 3?
    THANKS
    Dec 2004
    Australia
    Well from recollection suite 1 is Nero burning rom, etc. suite 2 is recode and related and suite 3 is Nero mix or at least something like that.
    Just go to the nero site and look up the contents of suite 3, then if the installer on your CD includes those apps, it has suite 3.
  5. Here's a comparison of the 3 - get Suite 3 if you can, as it's practically the same as the full version of Nero:
    http://www.softwareandstuff.com/SWW12252.html
  6. Member Theophilus's Avatar
    Aug 2003
    northern carolinas
    So what is the functionality of the DVD plug-in on suites 2 and 3? Do you have to have it to burn DVDs (i.e. will suite 1 not burn dvds?)? Which suites burn dual layer discs? Thanks.
  7. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    They will all burn DVD's. There are just added apps in each of the different Suites which most people don't use anyway (All I ever use is Nero Burning Rom).
    As long as you have the latest patches, dual layer is supported.
