Please help. I've edited home video in Adobe Premiere Pro and converted to a 12 gig movie file. I use DVD Santa to convert to VOB files then burn. Problem is Santa compresses to 2.88 gigs not 4 gigs. The final DVD when played on a TV is very jerky with motion. I assume it is a compression problem. Is there a way to improve quality to eliminate the jerkyness?
Thank you.
First, use a dedicated standlone mpeg encoder (such as tmpGenc, Procooder, CCE etc) to convert your files to DVD compliant mpeg. The advantage of a dedicated encoder is that it gives you full controll of all the settings, but it may take some reading and learning to get the best out of it.
Then use a dedicated DVD authoring program to convert the mpeg into VOB files etc.
BTW 12Gb of DV avi is less than an hour, so at DVD's max bitrate, 3 Gigs is not that far off what you would expect. The jerkyness is probably down to something else such as wrong field order.There are 10 kinds of people in this world. Those that understand binary...
What is the best way to author a dvd...AKA GET RID OF THE JITTERS!
By burrowsfan in forum Newbie / General discussionsReplies: 12Last Post: 20th Feb 2009, 13:57 -
Want to keep 5.1 but Nero Vision 4 DVD jitters from AVI file
By CoachSerpico in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2008, 08:21 -
AVI file picture jitters in stand alone dvd player
By pattirose in forum Software PlayingReplies: 4Last Post: 22nd Jan 2008, 15:23 -
A NOOB overcomes the jitters (a workaround)
By dADDo in forum Newbie / General discussionsReplies: 1Last Post: 26th Nov 2007, 03:24 -
Help; DVD plays in frames; Sound Jitters
By Brother Ali in forum Software PlayingReplies: 7Last Post: 1st Jul 2007, 04:50
