Most of the time when I play a divx file, everything's fine...audio and video wise. Recently, I downloaded a few files where the video is fine, but in some parts of the movie the volume goes way down. As the file continues to play, loud "chirping" sounds intermittently happen. Then all of a sudden, the audio is OK again. If I stop viewing the file, then restart it, the same thing happens again, and in the same spots.
I washed the problem files through Gspot, and they say that all is well. Keep in mind- only SOME of the divx files I download are like this. All I can think is that it just so happens to be bad files I'm downloading or bad codecs in my system...but it's the SAME kind of chirping in the multiple bad files. Any insight into this subject would be greatly appreciated!
This is usually caused by bad files. Somewhere along the way, garbage has gotten into the file.
Sometimes you can correct this issue. Check in the "How To" section under "EDIT". There should be a guide or two there for correcting damaged files.Google is your Friend
DivX Converter Audio Problems
By maccool111 in forum AudioReplies: 3Last Post: 28th Mar 2010, 04:47 -
Audio Sync Problems when converting MPG to Divx
By kbehel in forum Video ConversionReplies: 1Last Post: 16th Jan 2009, 22:18 -
How do I convert DVD movie to DIVX w/o Audio Syncs problems
By peggypwr1 in forum Video ConversionReplies: 10Last Post: 1st Aug 2008, 18:22 -
Converting Divx w/ Vorbis audio to Divx w/ MP3
By tachyon2u in forum AudioReplies: 3Last Post: 24th Feb 2008, 00:35 -
Audio Problems with divx,xvid etc on dvd player
By iain123 in forum AudioReplies: 6Last Post: 30th Jun 2007, 15:57
