I'd like to know if it is possible to extract entrypoints from ENTRIES.VCD.
For example 10.12.33 / 18.05.45 and so on.
The same question goes to the Menue Images of a VCD. Is it possible to extract them and save them as bitmap or JPG or any other picture format?
Thank you
Well, Entry points I am not sure of.
Menus however are usually picture files to start with (at least the way I make them), converted in to a still image MPG file - but can theoretically be actual video files (I have done that a few times).
If the menu you are talking about is just a still image - basically if you could simple play it using a DVD player on a computer and capture the menu image (Power DVD allows you to do this) you now have your image file.
How to extract audio from a VCD?
By c1steady in forum AudioReplies: 2Last Post: 14th Jan 2010, 21:16 -
main menue & submenue are not working properly with GFD
By akakiami in forum Authoring (DVD)Replies: 1Last Post: 29th Sep 2008, 07:14 -
Extract audio only from VCD
By ambrosechapel in forum AudioReplies: 2Last Post: 19th Aug 2008, 22:24 -
How to insert a video in a DVD that have menue without re-processing all?
By whenloverageswild in forum EditingReplies: 0Last Post: 26th May 2008, 08:47 -
extract vidio and audio from VCD
By Z.K. in forum Newbie / General discussionsReplies: 2Last Post: 15th Jun 2007, 13:50
