Say I have a file (.mpg or a .m2v or whatever - NOT a VOB, or VIDEO_TS folder). How can I easily find out if it is PAL or NTSC? I assumed MPEG2WORKS's Tools pane's MPEG Info window would show such but it does not.
I know I can load some into Toast and select to make a PAL or NTSC SCVD and if any of the files are not the selected format Toast will balk. I can then add and remove until all files are the same and Toast will automatically choose one or the other. Kind of a PITA to do if there is some app out there that has a feature that shows you PAL or NTSC.
Thanks,
mf
Just open it in Quicktime and look at the fps. 25 = PAL, 23.976 or 29.97 = NTSC
This is assuming the resolutions are standard. -
Thanks for the very quick reply. In QT how do I find the fps? It *is* shown in MPEG2WORKS info on the Tools pane. I just didn't know what I was looking at. Shoulda said up front that I knew next to nothing!
So, I now know how to easily do what I want with what I had first tried. But, out of curiosity, how do I see fps in QuickTime? I assumed it was Movie>Get Movie Properties, but I don't see anything related to fps. Size, yes, but not fps. Just curious now.
Again, thank you,
mf -
If you change the Movie pull down menu to MPEG Muxed Track, and change the second pull down to Frame Rate, then it will show you the fps.
D'oh!
And, D'oh again. Thank you. Talk about half-assed effort. I swear I'm not really that stupid.
Take care,
mf
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
auto-detect NTSC or PAL for VHS?
By matt9b in forum Capturing and VCRReplies: 17Last Post: 3rd Jun 2011, 04:28 -
NTSC MPEG2 file to PAL M DVD
By Ed2009 in forum DVD RippingReplies: 2Last Post: 28th Sep 2009, 00:05 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19 -
Subtitles not added during conversion of Pal to NTSC 2 avis with 2 sup file
By unity860 in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 3rd Apr 2008, 07:54
