i need to know if this is possible, or am i missing something, or just out too lunch.
i have an mpg that is saved in PAL format. i want to convert it to ntsc using tmpgenc. when i do it now, the audio and video are in sync at the start, but at the end of the vcd they are out, video ends up ahead of the audio some 8 to 10 seconds.
my question is, if i convert in tmpgenc to ntsc, but leave the frame rate set for pal, will the final product still be ntsc compatible? ie using the ntsc profile in tmpgenc just manually turning back the frame rate to keep it the same was the original?
is this feasible?
thanks in advance,
Cdn
Results 1 to 1 of 1
Optimal settings for conversion
By airwolfUK in forum Video ConversionReplies: 1Last Post: 17th Feb 2011, 14:08 -
TMPGEnc Settings?
By chronic777 in forum Video ConversionReplies: 3Last Post: 27th Jul 2009, 09:14 -
MKV conversion settings help
By pianoman0723 in forum Video ConversionReplies: 1Last Post: 6th Sep 2008, 10:39 -
HD->SD Conversion - Settings Help!
By Russell_hq in forum Video ConversionReplies: 0Last Post: 20th May 2008, 08:33 -
Conversion settings for ipod touch in Plato
By zionsgirl in forum Video ConversionReplies: 0Last Post: 12th Jan 2008, 18:34
