after problems with vcdimager saying it doesn't like my mpeg files, i re-encode them with tmpeg encode, 320x240, 29.97fps (vcdimager now is okay with them), and burn it to video cd using cdrwin. sometimes the video is fine. sometimes the video only takes up the left 40% or so of the screen. sometimes re-encoding with tmpeg fixes the problem. a lot of the times it doesn't. what's going on?
My first thought is that your DVD player doesn't like xVCDs. Try encoding at 352x240 (VCD standard) and see what happens. You can make a short 1-2min clip to test. Although in theory any resolution that can be dived by 8 shold work I'd stick to:
352x240, 352x480, 480x480 or 720x480.
video clip squished/squeezed from the sides
By shaema in forum Video ConversionReplies: 4Last Post: 10th Apr 2011, 13:23 -
image squished vertically and letterboxed
By blitzen in forum Newbie / General discussionsReplies: 1Last Post: 10th Aug 2009, 19:01 -
Exporting video is Squished (Horizontally)
By Daniel Arroyo in forum MacReplies: 3Last Post: 22nd Oct 2008, 09:06 -
DV AVI to FLV - Squished video - aspect ration 4:3 really 3:2???
By Tfp in forum Video ConversionReplies: 4Last Post: 6th Jun 2008, 19:54 -
Problem with 480p capture. Video seems squished...
By Mysteriouskk in forum Capturing and VCRReplies: 11Last Post: 9th Feb 2008, 01:24
