Guys,
When I have the 2 options widescreen and normal screen on the DVD, and I just want to burn the wide one, how I know which one is that ???
You can use IFOEdit's inbuilt DVD Player to preview each title (or any other software player, for that matter). Also, DVDDecrypter and possibly smartripper can tell you the aspect ratio in their "Stream Processing" modes AFAIK.
If in doubt, Google it. -
Look at the file sizes in DVDDecrypter. Determine whether the widescreen is bigger/smaller and then use that info when choosing which one you want to transcode in DVD2ONE.
How to PROPERLY burn DVD2ONE DVD's using TOAST 6.0
By galactica in forum MacReplies: 170Last Post: 30th Mar 2012, 03:48 -
DVD2One: Unable to create vobfileset 0...
By Ryan Kelly in forum MacReplies: 3Last Post: 27th Nov 2009, 11:00 -
Weird DVD2one conversion-7 GB compressed to 2.6 GB on diskcopy, why??
By ruggerjvd in forum MacReplies: 2Last Post: 2nd Jan 2008, 11:26 -
Question about seamless joining in DVD2One
By jwnulife in forum MacReplies: 12Last Post: 20th Dec 2007, 07:03 -
Program like DVD2ONE?
By Soccerman77 in forum Newbie / General discussionsReplies: 7Last Post: 26th Nov 2007, 17:11
