I understand that Mainconcept Encoder allow you to split the AVI while encoding into few smaller that can fit into a CDR.
Can TMPGENc Plus do that? How?
Mainconcept can do it on the fly I thinnk this is what he wanted to know.But yes it would be better to cut the video after encoding.
hi jim, i saw there is a mpeg tools, but no cut and merge button.
it contains option like simple mutiplex, siple de-multiplex, multiplex, de-multiplex, merge & cut.
is it under "merge & cut"?
how to cut the mpeg file?
thanks -
Yeah ... add your file, then double-click on it and change the range to the part you need. Change the Type to what you encoded your file to and then set an output file. Click Run when you've set everything to how it needs to be.Originally Posted by ranger2020If in doubt, Google it.
Splitting video files
By higgins327 in forum EditingReplies: 2Last Post: 13th Apr 2011, 14:36 -
How do I keep DV files from splitting ?
By RWANDREWS in forum Capturing and VCRReplies: 3Last Post: 15th May 2010, 03:07 -
Cutting/Splitting AVI Video Files Software
By Teac23 in forum EditingReplies: 1Last Post: 29th Oct 2009, 06:23 -
Splitting AOB files
By DeadSirius in forum Newbie / General discussionsReplies: 0Last Post: 23rd Dec 2008, 15:35 -
problem splitting mpeg with tmpgenc
By jensiq in forum EditingReplies: 16Last Post: 16th Sep 2008, 08:18
