Hi,
1)I intend to split an AVI file which was ripped from DVD into two so that i can convert into VCD.
I had followed the guide given here by using VirtualDub. I follows the instruction given but got ths message:
"VirtualDub Error:
The source video stream uses a compression algorithn which is not compatible with AVI files. Direct stream copy cannot be used with this video stream."
Anyone know what it mean? How can i rectify it.
Any solution please/alternative way of splitting an AVi file?
As I said in your other thread, your encoding software should let you specify a range you wish to encode. Either that or you could use a simple AVISynth script as input to your encoder and use the Trim() function to specify your range.
If in doubt, Google it.
need help cutting and joining avi files in virtualdub
By granturissimus in forum EditingReplies: 3Last Post: 31st Jan 2011, 02:53 -
I have an issue with cutting a portion of an avi file.
By darksniper in forum EditingReplies: 4Last Post: 9th Oct 2009, 20:23 -
problem with cutting AVI in half with VirtualDub.
By eroy in forum EditingReplies: 1Last Post: 27th Dec 2007, 06:53 -
help cutting an AVI file
By ethandeitrich in forum EditingReplies: 2Last Post: 24th Oct 2007, 00:25 -
cutting an AVI file
By ethandeitrich in forum Newbie / General discussionsReplies: 1Last Post: 24th Oct 2007, 00:03
