Having problems capturing with a Hauppauge WinTV card using Virtualdub. Using the guide on this site (PICVIDEO MJPEG codec), but getting audio/video sync problems. Tried the trick on the guide (set audio and video to be same length under Frame Rate), but still no good. Does anyone have any ideas - I get a couple of dropped frames when the capture starts then none till the end. Using compression setting 18 on the PICVIDEO codec and "CD QUALITY" for audio. I've got the "lock video to audioW selected too.
Any suggestions gratefully received.
try using FREEVCR and tell me if it will sync, I have the WINTV FM and is out of space to try.
'capture/timing/adjust video clock dynamically to match audio clock' is the setting that applies to virtualdub internal mode captures. 'capture/settings/lock video stream to audio' is only for compatibility mode which is to be avoided
Tried the settings recommendation in virtualdub but no luck (it was set anyway) - still got sync problems. No better luck with FreeVCR. However - tried AVI_IO and excellent results - no sync problems at all so willbe sticking with that I think.
Thanks to those who offered advice
hauppauge 1212 and wintv extend
By tkolt in forum Media Center PC / MediaCentersReplies: 0Last Post: 18th Nov 2011, 19:56 -
Need Help Capturing with VirtualDub and Hauppauge WinTV via Svideo
By ibAdam in forum Capturing and VCRReplies: 5Last Post: 21st Aug 2011, 22:01 -
Hauppauge WinTV-PVR 250
By thatsgame1 in forum Newbie / General discussionsReplies: 5Last Post: 22nd Jun 2011, 07:54 -
Hauppauge WinTV and MS Net .Framework
By ionavideo in forum Capturing and VCRReplies: 0Last Post: 2nd Jun 2010, 05:29 -
Considering Hauppauge WinTV PVR 350...
By chewie8008 in forum Capturing and VCRReplies: 9Last Post: 2nd Oct 2007, 18:20
