Hi guys.
I recently got a new comp that has Win XP Home SP2 on it...and much to my surprise, I found out I couldn't play my copy of Championship Manager 01/02 like I could on SP1.
I have a copy of Partition Magic 8, but I can't seem to get it to partition my 80 GB HDD, and I don't want to re-format b/c then I have to deal w/ M$ and the re-activation process.
Any idea what I should? Is there an alternative partitioning software available?
Thanks,
Jie
Results 1 to 10 of 10
(1)BenQ 1620 w/ B7u9 w/ MCSE speed patch
(2)Philips 8631 @ BenQ1620 w/ B7U9 w/ MCSE speed patch
GET MCSE HERE
BenQ Ownz j00 -
Can't think of any reason Partition Magic couldn't do what you want... It is probably the most recommended prgm for this type of task...Originally Posted by Ma_Jie
makntraksIn the theater of the mind...
It's always good to know where the exits are... -
It doesn't work for me, mate.
See below. When I try to create a partition, I can't. The Wizard doesn't work & the menu option is grayed out.
- JIE
GET MCSE HERE
BenQ Ownz j00 -
There appears to be a small "hidden" partition, probably for recovery, to the left of you C. If I did the math correct this "hidden" partition is 4869.1 MB. My guess is is this is the partition that Partitionmagic is complaining about.
What happens why you try the operations menu? -
Hi guys, I got it to work. I re-distriubuted that hidden partition back into C:\ then made a 2 GB partition.
Thanks for the replies guys,
- MJ(1)BenQ 1620 w/ B7u9 w/ MCSE speed patch
GET MCSE HERE
BenQ Ownz j00 -
Did you look for an update?Originally Posted by Ma_Jie
Vendors updated programs so that they would function correctly under SP2. -
Hi Bazooka. As best I can tell, no patches, etc were released for CM 01/02. Eidos, the maker of the game, now has CM 5 out; but given that I've been playing this game for 3-4 years now and am very deep in it (only 6-7 seasons left till the game is over), I don't want to buy the new one yet.
What I'll do is make a 2 GB partition (successful), then just put Win XP on it, without the SPs, so I can play. ^_^
Cheers,
Jie(1)BenQ 1620 w/ B7u9 w/ MCSE speed patch
GET MCSE HERE
BenQ Ownz j00 -
Good news guys:
I got it to work under comptability mode
Cheers,
JIe(1)BenQ 1620 w/ B7u9 w/ MCSE speed patch
GET MCSE HERE
BenQ Ownz j00
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 15:35 -
Question about partitioning a HDD with GParted
By FulciLives in forum ComputerReplies: 1Last Post: 9th Feb 2009, 18:15 -
Question about partitioning Windows during new xp install
By jimdagys in forum ComputerReplies: 6Last Post: 5th Nov 2008, 18:57 -
Best/Ideal HD partitioning for a new WinXP Pro installation
By retroborg in forum ComputerReplies: 4Last Post: 12th Oct 2008, 08:45 -
Need Advice Partitioning New Comp
By videocheez in forum ComputerReplies: 5Last Post: 27th Jun 2008, 03:37
