I've just bought a Liteon 5006 recorder and understand from flanina... (clever chap) it won't ouput a dvd signal via RF.
This is a problem for me, it means I can't run the signal upstairs to the loft and on to each bedroom.
My original setup, comprising a dvd player and sky tv box connected to a VCR was fine, and the resultant RF signal from the VCR would happily send itself around the house.
Does anyone know a fix, are all DVD recorders the same?
Thanks,
Will
tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
Use your VCR to convert the video output from your DVD recorder to an RF signal.Does anyone know a fix
Yes.are all DVD recorders the same? -
Yeah, just run into your vcr, using the rca connections (or s-video, for the video, if you are lucky enough to have a vcr with an s-video connection), and then run the rf output of the vcr to whatever you like. I do it all the time. Good luck, and enjoy.
ThanksOriginally Posted by Racer2x
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Hey.
I've been thinking about this (but have yet to test it, sorry) and my original setup was a macrovision removed scart to scart (from the dvd player to the VCR) so surely, if I run the composites to the VCR they'll be some form of copy protection involved, right, even though I'm not copying, only outputting?
my vcr only starts the macrovision when I press the record button, and some vcrs just have it when you plug it up, even without pressing record. But I think most vcrs will output a clean signal as long as you dont press record. Is that what your asking?
Kind of, thanks.Originally Posted by solidsnake
I seem to remember seeing a distorted image upstairs (in bed 1) when I ran the dvd signal through the vcr and up into the bedroom.
This went away when I connected the macrovision remover scart thingy, and figured it'd be the same with the dvd recorder.
Trouble is, I don't have a macrovision removal thingy in the form of a composite to scart.
Loud buzz when outputting audio only
By joelkranz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 15th Mar 2014, 23:12 -
AVI to DVD not outputting Video_TS or Audio_TS folders
By threesixes in forum ffmpegX general discussionReplies: 18Last Post: 30th Dec 2008, 02:23 -
SPDIF not outputting correctly from PC
By bear2616 in forum AudioReplies: 4Last Post: 12th Nov 2008, 17:59 -
Splitting a video in several parts and outputting in one go?
By bigMach™ in forum EditingReplies: 12Last Post: 12th Jul 2008, 21:15 -
Outputting to DVD from 16x9 source
By yadda in forum Newbie / General discussionsReplies: 6Last Post: 24th Jul 2007, 22:02
