Hi Folks,
After following some good advice on this site, I recently purchased an AIW Radeon 7500 card. It's installed, and working -- but there's a niggly little problem that is driving me nuts.
When I first installed the card, I could watch television in a window on the screen (resizable to whatever scale I wanted). I could also change channels using the remote control, and the channels would change in the little window.
However, I've changed something at some point, and now I'm unable to change channels in that little window. I can still view the television in the little Window, but whenever I press the channel buttons on the remote control, the little window automatically scales to full-screen. The channels change fine then, but I don't want to be in full-screen mode all the time.
As well, no matter what I've set as "Video Size" in the set-up menu, the TV feature always launches full-screen (with no tv control panel displayed). I always have to hit ALT-F to exit Full-Screen (at which point the window size goes to the correct size...but with no ability to use the remote without it going back into Full-Screen mode)
Any ideas?
(I have MMC v9.02 installed).
Keith.
I should point out that I can still change the channel in the smaller windows by using the on-screen channel change controls -- just not with the remote control.
And after further experimentation, it seems that whatever I hit on the remote control (even mute) automatically changes the screen size to Full-Screen.
Baffling... -
Well, I've solved my own problem. It turns out that I had the EasyLook configured to automatically load whenever I used the remote control.
Not sure what EasyLook does...but I've disabled it for now.
I'll do some more research and try to figure that one out...
No reference to it in any of my manuals...
Keith.
Full Screen Ripped DVD is not Displaying Full Screen on Widescreen TV
By jgciamarra in forum DVD RippingReplies: 3Last Post: 23rd Jan 2012, 17:42 -
Windows Media Player 8 full screen DVD playback not full screen
By brassplyer in forum Software PlayingReplies: 1Last Post: 3rd Jan 2012, 15:43 -
ATI AIW 7500 64M Replacement?
By TaranScorp in forum Capturing and VCRReplies: 20Last Post: 6th Aug 2009, 11:56 -
DVD Lab Pro, help mixing full screen and wide screen.
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 31st May 2009, 17:23 -
ATI 7500 AIW capture problems
By saoneg in forum Capturing and VCRReplies: 8Last Post: 6th Mar 2008, 05:11
