Results 1 to 21 of 21
  1. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    hello everyone, my friend sent me an MPEG file, and it played fine on RealPlayer and Windows Media Player (and all other players that i have). however when i try to run it through TMPGEnc to trim it and etc., i recieve this error:
    please help. thanks.
    Wow! You got shocks, pegs... LUCKY!
    Jul 2004
    N/A
    Hi,
    That is because the plain version of TMPGEnc does not support MPG file conversion.. only AVI files. If you want to convert MPG files you have to use TMPGEnc Xpress.
    Regards,
    diE
    LiVe iS juSt EvIl SpElLed BAcKwArDS!
  3. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    are u sure, because i have used TMPGEnc many times to trim my MPGs and output them as the same format. i dont mean to defy you, just asking if ur sure
  4. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    If it is an MPEG-2 file then run it through DVD2AVI or DGMPGDec and get yourself a D2V project file (with demuxed audio). TMPGEnc Plus will open the D2V file.
    If it is MPEG-1 then I think TMPGEnc Plus should open it direct. If not try loading it into VirtualDubMod and then frameserve to TMPGEnc Plus.
    Might also want to "play around" with the environmental settings ---> VFAPI plug-in TAB.
    - John "FulciLives" Coleman
  5. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    um ok, but i dont quite know what Frameserving is, can u please explain... thanks
  6. Member FulciLives's Avatar
    May 2003
    Look in the GLOSSARY (see left hand bar) and search the ALL GUIDES section (see left hand bar).
    That is why that stuff is there
  7. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    ok thanks
  8. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    man, i tried loading it into VirtualDubMod and TMPGEnc Plus, but no dice, they dont accept the file, and say it is either unsupported or corrupt, what now...?
  9. Use AVICodec or Gspot to read the file. Post a screenshot here.
    In TMPGEnc try after increasing the DirectShow filter priority to the highest level so that it reaches the top of the list.
    When I was born I was so shocked that I could'nt speak for 18 months.
  10. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    ok i ran it thru AVIcodec and it gave me this:
    i thought it was kinda wierd, it says something about MPEG Layer-3 and DivX 5, what does that mean?
  11. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    GSpot gives me this:
  12. If I remember you initially said about mpeg file now the screenshot is of an AVI file ??
    GSpot tells you that it is an AVI file and that codecs are not installed. So you have to install DivX codecs.
  13. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    ok how do i find out what divx codecs to install? where can i find them?
    Nov 2002
    GSpot and AVIcodec both told you what codec to use. That's what those programs are for. Look on the left for tools and select codecs.
    You can either download the DivX5 codec or the XviD codec that will read all DivX files. I would recommend the XviD codec.
  15. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    ok i got the Xvid Codec, now what do i need to do?
    Nov 2002
    >>ok i got the Xvid Codec, now what do i need to do?<<
    That depends on what you want to do with it. If you want to edit it, open it in Virtualdub.
  17. Member monzie's Avatar
    Nov 2003
    The Village
    Rename the file with an .avi extension instead of .mpg... (its the FIRST thing I would do).
    PS. How come in your FIRST screenshot its 'mixtape vol 6.mpg'...but later on its 'mixtape vol 6.avi'??????????????
    PPS...where did you get the file?
    No2: We want Information.
    No6: You wont get it!
  18. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    because i used AVIDemux to make an MPG of the AVI, but it didnt work.
  19. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    i did a little of research in the TOOLS and found kinda what i needed, i used WinAVI Video Converter to convert the AVI to an MPG, worked pretty good.
  20. WinAVI is OK. but it does not give you much options like other encoders like TMPGEnc, MainConcept, CCE.
    I have used WinAVI to encode many files and sometimes I have noticed that in bright scenes there is some very slight "matte effect"
  21. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    thats true, but it was able to convert my AVI (packed with some DivX watever) to MPG, which TMPGEnc couldnt do...
