    Jul 2004
    N/A
    Hi,
    Is there a possible way to convert a PAL DVD to NTSC in DVDShrink as it has a Region DVD tab.. so I was just thinking if it was possible. Another question. I read on DOOM9 that when you re-author in DVDShrink you cannot keep the menu's from the previous DVD... well is it possible to keep the menu's from the previous DVD after removing extras, commentaries, and additional audio tracks? That is because I just want to remove the links to the files that have been deleted so they don't stay on the DVD.. any help? Is there anyway to do this without re-authoring the DVD?
    Regards,
    diE
    LiVe iS juSt EvIl SpElLed BAcKwArDS!
    Apr 2004
    Miskatonic U
    Didn't you ask this same question here -> https://www.videohelp.com/forum/viewtopic.php?t=262376&highlight=
    Read my blog here.
