I have 3 movie I want to author. What I want is
----------Menu--------
movie 1 2 3 |
with motion menu. I then want to divide each movie to chapter. So when I click on movie 1.
it'll be
Movie 1
pt1 p2 pt3 |
Before I dive into tmp dvd author 1.6 does any1 know if it 'll be able to do this or must I look into dvdlab?Thanks.
Computer Spec:
winxp pro, 2.4ghz, 768mb ram, 100gb -
Yes, you will be able to do this with TMPGEnc DVD Author with no problems.
You will have to add each movie as a seperate Title (or maybe it's called a Track in DVD Author, don't remember). Then you will be able to edit each title and create their own chapters individually.
I could tell you exactly what to click to create Motion Menus but right now I am not at home so I can't see the program. If I remember, I will give you all the details later when I go home.
Author mts files with menu to DVD
By rancid in forum Authoring (DVD)Replies: 0Last Post: 29th Jul 2011, 01:17 -
menu problem in TMPGEnc DVD Author 3
By sanduul in forum Authoring (DVD)Replies: 13Last Post: 23rd Oct 2007, 20:20 -
TmgEnc DVD Author Menu Problem
By powerkoala in forum Video ConversionReplies: 9Last Post: 25th Sep 2007, 14:19 -
TPMGEnc DVD Author 3 Menu Problem
By ^D3vIL^ in forum Newbie / General discussionsReplies: 4Last Post: 16th Sep 2007, 18:43 -
Menu troubleshoot using Tmpgenc Dvd Author
By tekka06 in forum Authoring (DVD)Replies: 8Last Post: 4th Jul 2007, 04:53
