Hi,
I am relatively new at this capturing thing and I have been succesful at transfering a few VHS tapes to DVD but when I started trying to transfer my old Beta tapes, I get Dropped Frames (about 100 per minute) and Audio Out-Of-Sync problems.
From this, I gather that the quality or strength of these Beta tapes are not as good as the VHS, is this correct?
I know that it is not the VCR that's giving the problem given that it is one of the last models manufactured by Sony (SL-HF2100), which is quite fancy, and it's in practically mint condition. As well, the tapes I am trying to transfer are originals and in perfect condition.
I am using an ATI capture card and Nero Vision 3.
Any info on how to get around these problems would be greatly appreciated as I would like to preserve these out-of-print titles that I have on Beta.
Thanks.
The "strength" of the tape has nothing to do with it.
Nero sucks at capture.
Try capturing to DV-AVI, or avi with a picvideo mjpeg or huffyuv codec, then encode.
I'm sure that our resident smurf will be along soon, with some great ideas for capping with an ATI card
Cheers, Jim
My DVDLab Guides -
Thanks Jim.
I am not too technical on this subject so I am not sure about these codecs that you mentioned.
Besides Nero, I also tried Pinnacle Studio 8 and got the same dropped frame results. This was done directly to MPEG2. Will capturing to AVI make a difference in the "dropped frames" department?
I also forgot to mention that I am using Composite inputs. My VCR has S-Video outputs but I don't have a S-Video cable. If I get a hold of one of these cables, will it make any difference?
thanks again. -
A smaller aspect ratio will make a difference in drops, as should DV-avi.
Capping by one method or the other should be the same speed.
The problem is that you're trying to cap direclty to mpeg-2, and at full d1 (720x480) this requires a LOT of speed. Cap to avi (with a good codec), requires much less, no matter what cable you use.Cheers, Jim
My DVDLab Guides -
Do this to capture:Originally Posted by lerxst
http://www.digitalfaq.com/capture/atimpeg/atimpeg.htm
or
http://www.digitalfaq.com/capture/atiavi/atiavi.htmWant my help? Ask here! (not via PM!)
Convert all MiniDV tapes to computer and say good bye to those tapes
By iho in forum Video ConversionReplies: 38Last Post: 17th Dec 2013, 01:01 -
I need to transfer my miniDV and old hi8 tapes tapes to dvd
By bryanport in forum DVD & Blu-ray RecordersReplies: 9Last Post: 21st Dec 2012, 20:53 -
Trying to play old Beta tapes
By razielle in forum RestorationReplies: 10Last Post: 6th May 2010, 10:54 -
creating mov files from mini dv and beta sp tapes
By bruceinva in forum Newbie / General discussionsReplies: 5Last Post: 16th Mar 2009, 15:14 -
Questions on converting Beta tapes to DVD and quality
By rbatty11 in forum Video ConversionReplies: 7Last Post: 30th Apr 2008, 16:54
