Hi there,
I am using Goldwave to take a wav file from an avi. There is about 23 seconds at the start of the avi where there is no sound. The first sound in the video starts at 23 seconds.
After resampling and converting to wav, somehow, the silence that should be 23 seconds long is only 9 seconds long so then when I try to use the wav and avi together to make an mpg file (using TMPGEnc), the audio is out of sync. Why would this be? The original avi is all in sync.
Can anyone help?
Thanks for reading.
chromeman
How would I find out if the audio is VBR MP3? Using Virtualdub?
Thanks for your reply
chromeman -
Yes if the AVI file has VBR MP3 audio, then virtualdub will give you a warning...Originally Posted by chromeman
Converting an AVI file in Toast PROBLEM!!!!!!!!!!!
By thasco in forum MacReplies: 10Last Post: 14th Dec 2010, 11:44 -
Converting WAV file to Dolby Digital® 5.1 Surround
By roma_turok in forum User guidesReplies: 18Last Post: 16th Nov 2008, 23:32 -
Audio problem when converting a MPEG file to AVI
By Kareng in forum ffmpegX general discussionReplies: 9Last Post: 18th Jul 2008, 18:50 -
By Kareng in forum AudioReplies: 1Last Post: 2nd Jul 2008, 16:56 -
goldwave and wav codec
By natty in forum Video ConversionReplies: 4Last Post: 15th Jun 2007, 08:57
