I'm used to frameserving from virtualdub, and familiar with a lot of filters.
I have a cartoon, and this is new for me. I'm used to doing dv cam, and movie stuff.
It's a fairly old (1950's) originally on film, and it's not blurry, but it's "fuzzy". Edges are not sharp at all. I don't know if it's interlaced or not, but that doesn't seem to have any effect.
I've tried the normal sharpen filter, and msharpen by Donald Graft, but nothing seems to clean up the edges, without destroying the video somehow, macroblocking, streaking, among other things.
Is there some different vdub filter I should be using, or combination?
How about tmpgenc settings, anything there I could use to sharpen it up?
Cheers, Jim
My DVDLab Guides -
LordSmurf has some info on his page. Maybe you can PM him to see if he can send you the filter settings?
http://www.digitalfaq.com/dvdguides/restoration/video/intro.htm -
Cartoon Tool
Msu_sharp
Static Noise reduction / Dynamic Noise reduction (use lower values)
For cartoons, temporal smooth is also good, but not spatial based filters -
OK, now I gotta google all this stuff...
SatStorm, I have been trying the static/dynamic noise reduction, but I'll try msu_sharp and cartoon tool as well, thanks.
Do you mean MSU Deblocking, when you said msu sharp? I can't get it to work, and I tried all the suggestions in the thread on it.
Edit: Got them here: http://www.hlinke.de/Vdub-Filterlist/vdub-filterlist.html
I'll let you know how it all turns out.Cheers, Jim
My DVDLab Guides -
Hi, no I mean msu_sharpen.vdf
Slow but nice
http://www.compression.ru/video/smart_sharpen/index_en.htmlLa Linea by Osvaldo Cavandoli
I'm frameserving everything, so it's speed isn't that critical. Thanks for the link!
Cheers, Jim
My DVDLab Guides
Well, VHS capturing Mostly cartoons, having some questions:)
By zerowalker in forum Capturing and VCRReplies: 943Last Post: 31st May 2013, 00:30 -
Ripping Single Episodes of Cartoons for Re-Authoring - Jaggies
By jdmba in forum DVD RippingReplies: 7Last Post: 5th Aug 2009, 14:19 -
TMPGEnc Settings?
By chronic777 in forum Video ConversionReplies: 3Last Post: 27th Jul 2009, 10:14 -
Converting Cartoons to Xvid
By CartoonManic in forum Video ConversionReplies: 16Last Post: 15th Jun 2008, 17:31 -
TMPGEnc DVD settings
By Bully9 in forum Authoring (DVD)Replies: 3Last Post: 12th Mar 2008, 09:22
