Hey there,
I searched the forum and did not find an answer: has anyone noticed this, I do a backup with DVDRemake Pro, remove unwanted material, watch the DVD on hard-drive, doing fine, but when I put it into my Player after burning, there are these little stops during playback. Exactly like the layer-break in commercial DL DVDs.
Does anyone know, what I may be doing wrong? I remove unwanted material by using right-Klick and "Hide Block(s)", after having ripped the DVD to HDD with DVD Decrypter.
I have used VobBlanker successfully, combined with DVD2one etc., also Recode, but I like especially about Remake that you can remove/hide buttons and have a very graphic display/preview.
It sounds like you're using a copy of 2.62 (I think that's the version)
This problem was fixed in newer versions, so either buy it, or obtain a newer revision through whatever means you obtained your current copy. -
Actually here's a link to the Version History, as you can see this was a problem in version 2.6.2
http://www.dimadsoft.com/dvdremakepro/history.php
So if you do have a legitimate copy, then I would suggest you upgrade to the latest version. -
Thanks for the quick answers.
It is actually a copy of version 2.6.4. I looked up the bug-fix history under the link you provided, those stops are mentioned for v. 2.6.2 as you wrote.
Have you got other ideas, suggestions? -
Well if your copy is legitimate I would upgrade, if it's not then, I can't really come up with anything.
Personally I didn't want to buy DVD Remake Pro, so I make due using a combination of DVD Decrypter, DVD Shrink, Menu Edit, Menu Shrink, and VOB Blanker.
DVD Playback Stops then Restarts.
By PowerFalcon in forum DVD RippingReplies: 9Last Post: 2nd Jul 2011, 09:11 -
PS3 Stops Playback of AVCHD?
By tommy2010 in forum Authoring (Blu-ray)Replies: 1Last Post: 15th Dec 2010, 01:38 -
Highlight buttons in DvdReMake Pro menu
By c627627 in forum Authoring (DVD)Replies: 3Last Post: 25th Apr 2010, 18:21 -
DVDremake Pro button problem
By Yaro in forum EditingReplies: 2Last Post: 16th Aug 2009, 16:54 -
Premiere 6.5 - Playback stops after 20 minutes on NEW PC.
By Phase52009 in forum EditingReplies: 0Last Post: 29th Jan 2009, 18:55
