  1. Member GeorgeW's Avatar
    Feb 2005
    Hi,
    I see this in the list of future enhancements for DLP:
    We want DVD-lab PRO become the tool of choice for advanced users - to fill the gap that exist today in this price range.
    With PRO version it only starts, there are many future plans including:
    seamless branching
    multiple angles
    buttons in Movies
    parental Control
    and more
    I saw in another post that "Seamless Branching" is already included -- what would indicate "seamless branching" is working? I know I can setup all types of "Playlists" -- so does that mean "Seamless Branching" (and if so, then why is it still on the list of future enhancements)?
    Also, any idea for when multi-angle will be implemented -- there's some things I want to try with multi-angles
    One more question, when I add a CELL command, there's always a slight delay when that chapter kicks in. Is it possible to eliminate that slight delay (I know it's mentioned in the help that a delay might happen -- I was just wondering if that can be prevented).
    p.s. I"m amazed at what this software can already do, and I think this software is very "advanced" in its functionality (imho) -- adding multi-angle support will bring it to a new level...
    George
  2. Seamless branching is used between multiple VTS.
    It may already be implemented, but the site isn't updated yet.
    The cell delay is more dependent on the player, than the software.
    Multi-angle should be out by July, along with a few other fixes.
    Cheers, Jim
    My DVDLab Guides
  3. Member GeorgeW's Avatar
    Feb 2005
    Thanks reboot
    Looking forward to the multi-angle feature
    Any insight as to what the "other fixes" are???
    George
  4. Better burning engine. Better motion menu rendering. More accurate size estimation, and possibly video/audio realtime preview for sync adjust...
    Cheers, Jim
    My DVDLab Guides
