  1. Well,
    I am nubee to this field.
    I want to make a photalbum using transitions,title editor,music and convert them into a VCD.
    Since I am in India I find many of MPG resol is 352x258 when viewd on T.V.
    Now, I have Adobe preem 6.5. How to make the resol to 352 x 258 and what should be the frame rate. Kindly guide me....
    nat_59
  2. Try a tool specifically designed for this purpose.
    http://www.photo2vcd.com/
    When I was born I was so shocked that I could'nt speak for 18 months.
  3. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    If you want to use Premiere 6.5, create your slideshow on the timeline, then "Export Timeline" - "Adobe MPeg Encoder". Then check VCD and PAL for 352x288, 25fps.
    Encode the MPeg1, then use a VCD authoring program to author the VCD.
  4. Hi
    I have a small program to cut an image into 352x288 size which I coded in VB. If you (or others) need it please ask me at premjit_vp@rediffmail.com with subject 352x288.
    Bye
  5. Can I add Titles likd STarwars etc.
    nat_59
