what's a good menu program beside tmpgenc dvd author 1.6 that i can use to create menu's for my vcd formatted videos? If i use vcdeasy it only works on cdr's i guess, and im not sure of another program that's good for it.
Any authoring program can do it, as you are creating a DVD, not a VCD. What is your problem with tmpgenc DVD author ? What er you trying to do that it can't ?
Read my blog here.
Whats the best format for good video quality with reasonable file size
By hasanali00 in forum ffmpegX general discussionReplies: 2Last Post: 20th Feb 2010, 21:29 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 04:26 -
DVD Rom can burn DVDs but won't recognize burnt DVDs.
By soonie in forum DVD RippingReplies: 0Last Post: 23rd Aug 2009, 16:03 -
whats a good codec pack
By bmzxzx in forum Newbie / General discussionsReplies: 29Last Post: 7th Jun 2009, 18:58 -
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 15:34
