I would like to be able to read the DV tapes using a tape drive instead of the camcorder, but cannot find a supplier. Any suggestions please? Thanks.
Welcome to the forums.
Do you mean miniDV tapes?
If you mean to read them on a VCR like device then it is not possible as consumer oriented miniDV VCRs are not available (as yet). If you are likening this to old VHS-C tapes which had an adapter in which you could fit them and play on a standard VCR then again there is no such adapter available.
Studios have professional equipment that can directly read from DV tapes. Such equipments are usually very expensive.*** My computer can beat me at chess, but is no match when it comes to kick-boxing. *** -
There is the Sony DSR-11 which can play back PAL and NTSC. But it's true, as pbhalerao says, even this is at least US$2000. A better bet is a miniDV/S-VHS combo deck like those from JVC. Although I've seen it in the stores and in ads as I didn't pay much attention I don't know the model, but I remember the price tag: US$999. Still, Sony also has a DV tape drive meant to be installed in a 5.25" computer bay, to be linked via an internal FireWire connector. For transferring miniDV tape contents to the HDD to be used in a NLE this capture method has to be tops.
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i". -
This sounds Nice,I tried to look for it on the Sony site couldnt find it,Where did you see it?Sony also has a DV tape drive meant to be installed in a 5.25" computer bay, to be linked via an internal FireWire connector.
Thanks -
JVC HR-DVS3U is a combo deck - VHS on one side and miniDV on the other -- firewire i/o also..that model is the consumer version and there was also a professional version...a few more features .. that model is a year or so old, so there may be an updated version...b&h photo should sell whatever is the current version....surf the jvc web site and then price it at a few places incl b&h ( www.bhphoto.com )...and, that unit is certainly a minidv VCR...it can record to minidv off of RF (cable), from svhs / composite (no component input)..dub from vhs to minidv and the other way around...
"As you ramble on through life, brother, whatever be your goal - keep your eye upon the doughnut and not upon the hole."
Capture progressive mini-dv tape on interlaced mini-dv cam ?
By alip in forum Capturing and VCRReplies: 4Last Post: 8th Feb 2011, 18:27 -
HD Mini DV tapes to Digital
By oriopn5150 in forum Newbie / General discussionsReplies: 11Last Post: 3rd Aug 2010, 20:26 -
playing Digital8 tapes in 8mm tape backup drive
By jrh69ca in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 1st Dec 2009, 13:46 -
mini DV tapes. Any recommendations?
By foton in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 4th Apr 2008, 11:32 -
Hd Mini dv tapes via SD mini DV camcorder
By imptech3 in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2007, 03:11
