I am encoding my avi file to mpeg2. But the output is never satisfactory. The video seems worse than the original, and the audio is always out of sync. Can anyone give me some hint on how what to do?
Video quality depends on the quality of the original file and the encoding settings you use. If you are encoding for a DVD, separate the audio before encoding and add that to your authoring program. Encode the video separately and add that also, then author and burn.
Of course it does. Each reencode lowers the quailty, if you don't encode to a lossless format (which would amount to just a decode). Without more specifics on your source and destination, it's hard to pinpoint your problems.Originally Posted by easteast
/Mats -
My source file is compressed with pixl, which I capture from antenna using my PCTV rave card. I convert it to 6000 bits/s 2-pass VBR, with noise reduction, I-frame only. Actually I do not have much knowledge on the options, even I read the help content, as I do not what they really mean.
The output file is more blocky, noise is a bit reduced.
I hope to get something close to the source file. Is it possible? -
Hi,
Umm.. yes.. if you have a good computer.. try using TMPGEnc Xpress if you have any problems with plain simple TMPGEnc. Make sure the bitrate is atleast 6000 when being converted to MPEG 2.. and keep the audio and video as seperate streams.. if the video is too long you most likely are not going to get good quality. More than 2 hours is not meant for a DVD-5 so if you try to convert it to fit on a single DVD-R and it is longer than 2 hours than you probably aren't going to get quality video encode.
Regards,
DiRectLiVe iS juSt EvIl SpElLed BAcKwArDS! -
6000 bits/s is a way too low for I frames only. That is your bitrate is not enough. Even 6000 kilobits/s is low bitrate for I frames only.Originally Posted by easteast
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
tmpgenc 2.5 plus problem
By DSLGuy in forum Video ConversionReplies: 1Last Post: 3rd Apr 2008, 14:38 -
Problem with TMPGEnc
By The Monkees in forum Video ConversionReplies: 2Last Post: 1st Nov 2007, 15:58 -
TMPGEnc Problem
By djkevyb in forum Newbie / General discussionsReplies: 3Last Post: 27th Sep 2007, 15:46 -
TMPGEnc Problem !!!!!!!!!!!!!
By homantam in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2007, 17:56
