I'm putting together a DVD for my wife's real estate company - in other words, need software to put together PROFESSIONAL LOOKING MENUS!!! Anyone have any suggestions? Prefer something with automatic encoding. Thanks!
Results 1 to 9 of 9
dvdlab pro is one suggestion...some learning curve but once you pick it up, it can do a ton of things...no encoding though (are you sure you need that and wouldn't just encode your video separately?)...it's got a decent # of objects, but no 'theme templates' (e.g. real estate business theme) .... it's good if you have an idea of what you 'd like to do or if you are comfortable designing the whole thing yourself...if you want to load a pre-designed template and pop in some videos and have it encode (e.g. simpler, w fewer steps)..maybe others can add suggestions
"As you ramble on through life, brother, whatever be your goal - keep your eye upon the doughnut and not upon the hole." -
Agreed.You don't find anything better than Adobe Encore DVD.
What exactly don't you like about Encore? I use it all the time as well as DVD-LAB when I feel like it.
You can't produce somthing " Professional " with Encore?????? Are you kidding???No DVD can withstand the power of DVDShrink along with AnyDVD! -
If you want a "user-friendly" interface, take a look at Ulead's just-released DVD MovieFactory Disc Creator version 4.0. It takes a variety of sources, and has a builtin encoder.
New in version 4.0 is the ability to have text-only buttons, and you can move them around and re-size them at will (prior versions only allowed thumbnail buttons, and you could not resize or move them around).
For real-estate, pick your favorite background image, and use it behind one of the builtin templates.George -
I can't preview. Everytime I try to preview, I get Error Message 47003: No video decoder available for this stream type. I did a search online - plenty of others having this problem, but no one seems to know how to fix it. I've read where people were going to the extreme of uninstalling and reinstalling Windows to try and resolve this error but to know avail. One person even called Adobe and the person he spoke with didn't have a clue.... from what I've read, this error is a direct result of me installing either a program Encore doesn't like or a codec Encore doesn't like and for that reason, I am ineligible to use it unlike youOriginally Posted by jtoolman2000
Believe me, I'd love nothing more than to be able to partake of some of the best automatic encoding in the world, but until I get this situation resolved, it's DVDlab Pro and TMPGE for me.
Oh I see. Could there might be a conflict with something else in your PC? I can preview perfectly on my Encore 1.5 I am running it on a fairly fresh Windows XP Home install. I was having a few weird problems with strage things occuring on some programs so I re formatted and did a clean install. Everything is working perfectly now.
Encore DVD Menu Authoring
By montgal in forum Authoring (VCD/SVCD)Replies: 4Last Post: 29th Apr 2012, 23:24 -
Authoring Blu Ray in Encore
By Vasilis in forum Authoring (Blu-ray)Replies: 6Last Post: 19th Nov 2011, 12:44 -
Can anyone recommend a DVD authoring program that will fulfill my needs?
By smythotech in forum Authoring (DVD)Replies: 5Last Post: 17th Aug 2011, 17:37 -
Emergency Can anyone recommend a Solid authoring program?
By jbandy1 in forum Authoring (Blu-ray)Replies: 3Last Post: 27th Jan 2009, 12:51 -
Can someone recommend a good package for editing/authoring?
By bek in forum Authoring (DVD)Replies: 2Last Post: 31st Mar 2008, 16:20
